15 years ago --- Quote Start --- Therefore I think it is necessary to assign this node to PLL in PLL-section of assignment editor. --- Quote End --- It isn't. Simply connect the clock input to a PLL instance. Quartus will automatically select a PLL that has this pin as dedicated clock input. If you need to change this selection for some reason, assign the location to a PLL instance, not to the pin.
