skyviper
2 years agoQuestasim vdel
Questasim can't delete libraries using the vdel command. Each time I attempt to use the vdel command (GUI or Tcl), I get the following: vdel -all -lib tb_lib_path # wrong # args: should be "compi...
TingJiangT_Intel
Contributor
1 year agoSorry, but I am unable to reproduce your issue. Could you try running it on another server and check if the error might be due to your system environment? If the same issue persists, please share your reproduction steps with me so I can analyze the problem further. Thanks.
skyviper
1 year agocorrection... "-w" should be -work" and it still doesn't work.
