Questasim vdel
Sorry, but I am unable to reproduce your issue. Could you try running it on another server and check if the error might be due to your system environment? If the same issue persists, please share your reproduction steps with me so I can analyze the problem further. Thanks.
- skyviper1 year ago
I tried this on 2 separate machines and it fails the same way.
As part of this issue can you tell me why the -simulate command fails for qrun?
exec qrun -optimize -log [uplevel set reports_path] -outdir [uplevel set SIM_LIB_PATH] -top top_tb -o top_tb_out \
-makelib [uplevel set spi_dut_lib_path] -f [uplevel set spi_dut_filelist] -endlib \
-makelib [uplevel set dut_lib_path] -f [uplevel set dut_filelist] -endlib \
-makelib [uplevel set spi_tb_resuse_lib_path] -f [uplevel set tb_reuse_filelist] \
-vlog.options +define+[uplevel set SCOPE] -timescale=10ns/1ns -sv -end -endlib \
-makelib [uplevel set tb_lib_path] -f [uplevel set tb_filelist] -vlog.options -timescale=10ns/1ns -sv -end -endlibThis works:
eval vsim -work ./$SIM_LIB_PATH/$work_path -L ./$SIM_LIB_PATH/spi_dut_lib -L ./$SIM_LIB_PATH/dut_lib \-L ./$SIM_LIB_PATH/spi_tb_lib -L ./$SIM_LIB_PATH/tb_lib top_tb_out {*}$vsim_optThis doesn't:exec qrun -simulate -log $reports_path -outdir $SIM_LIB_PATH \
-vsim.options -w $SIM_LIB_PATH/work -L ./$SIM_LIB_PATH/spi_dut_lib -L ./$SIM_LIB_PATH/dut_lib -L ./$SIM_LIB_PATH/spi_tb_lib \
-L ./$SIM_LIB_PATH/tb_lib {*}$vsim_opt -gui=int -end top_tb_out -script $SIM_LIB_PATH/sscript.run - skyviper1 year ago
correction... "-w" should be -work" and it still doesn't work.
