skyviper
2 years agoQuestasim vdel
Questasim can't delete libraries using the vdel command. Each time I attempt to use the vdel command (GUI or Tcl), I get the following: vdel -all -lib tb_lib_path # wrong # args: should be "compi...
TingJiangT_Intel
Contributor
2 years agoPlease try this format:
vdel [-all] <library_name>
Use the library name instead of path, and don't use the '-lib' option.
- skyviper2 years ago
That doesn't work. Also, the GUI that does this for you uses this same syntax and doesn't work. I have been using Questasim for a long time and this always worked in the past and is how the manual tells you to do it. Can you get this fixed?
Did you check to see if this even worked?
Here is a screen show of the GUI attempting to do the same thing.
