jasns's avatar
jasns
3 years ago
Questa not working even after generating LM_License_File and setting environmental variable
The Questa Intel FPGA Starter Edition suddenly closes on opening even though after generating LM LICENSE file and placing it in its respective locations and also setting the environment variable.
The content in the native link simulation file is given below:
Info: Start Native link Simulation process
Info: Native Link has detected VHDL design -- VHDL simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : max10
Quartus root : c:/intelfpga_lite/22.1std/quartus/bin64/
Quartus sim root : c:/intelfpga_lite/22.1std/quartus/eda/sim_lib
Simulation Tool : questa intel fpga
Simulation Language : vhdl
Version : 93
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\questa
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/22.1std/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File Traffic_M_run_msim_rtl_vhdl.do already exists - backing up current file as Traffic_M_run_msim_rtl_vhdl.do.bak11
Info: Spawning Questa Intel FPGA Simulation software
Info: NativeLink simulation flow was successful
On giving RTL simulation, the below given was shown:
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "c:/intelfpga_lite/22.1std/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "Traffic_M" "Traffic_M")
Info (22036): For messages from NativeLink execution see the NativeLink log file C:/MVB_project_codes/Traffic_M/Traffic_M_nativelink_simulation.rpt
NB: no error is shown as I give RTL simulation and still VSIM is not opening. I could not rectify because no error is popping on the screen
Help to resolve this issue
Thank you
  • SyafieqS's avatar
    SyafieqS
    I dont understand, as you run the simulation via nativelink, the vsim command is not working? or the questa gui is not even launched?
  • SyafieqS's avatar
    SyafieqS
    May I know if you are able to solve the issue?
  • SyafieqS's avatar
    SyafieqS
    As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
