ELIT1
2 years agoQuesta Intel FPGA edition crash.
Hi. If you first add new signals to the waveform window and then restart the simulation, Questa will crash. If you restart the simulation first and then add signals, everything will be fine. I don...
- 2 years ago
Which operating system are you using? Please ensure that your operating system is supported.
You can check the list of supported operating systems here:Are you able to duplicate the crash using the example design from this Quick Start user guide and following steps 1.8 and 1.9?
Questa*-Intel® FPGA Edition Quick-Start: Intel® Quartus® Prime Pro Edition user guide here:Regards,
Richard Tan
ELIT1
2 years agoThanks a lot.
I use Windows 10 Pro, 22H2.
Design example works fine.
But I usually don't use simulation scripts, I create a simulation projects (.mpf).
There may be something that needs to be added to the simulation project.
I'll study the script from design example.
Thanks for the fast support!
ELIT1
