dsula1
2 years agoquesta: how to add command line option to modelsim.ini
Hi, For vlog compiler there's -svinputport command line options to select certain behavior. The default is -svinputport=relaxed. I would like to change the default to -svinputport=net. Is it possi...
dsula1
2 years agoUnfortunately adding svinputport = net doesn't work. Thank you very much for your reply.
I scoured the documentation. It doesn't seem possible. I guess I have to add it to the command line scripts.
