Questa FPGA Starter Edition Licensing Issue
So now I am where the OP was when he went private:
Can Intel please post a solution publically?
Does the license file have to be somewhere special? I tried saving to C:/flexlm but was not allowed access to save it there.
There appears to be a conflict with a Xilinx license? I need both.
C:\Users\RF>lmutil lmdiag
lmutil - Copyright (c) 1989-2019 Flexera. All Rights Reserved.
FlexNet diagnostics on Mon 1/17/2022 12:06
License file: C:\Users\RF\AppData\Roaming/XilinxLicense\Xilinx - Copy.lic
"XC7Z020_EMBEDDED" v2022.03, vendor: xilinxd, expiry: permanent(no expiration date)
vendor_string: [email protected],XC7Z020_EMBEDDED,software,permanent,_200503949_208823071_210739961_606
uncounted nodelocked license, locked to ethernet address "b89a2a3a225d" no expiration date
TS_OK: Checkout permitted when client is using terminal client
This is the correct node for this node-locked license
Enter <CR> to continue:
I am using:
Edition Windows 10 Pro
Version 20H2
Installed on 4/7/2021
OS build 19042.1466
Experience Windows Feature Experience Pack 120.2212.3920.0
You may want to start a new thread, since nobody has gone private on this one. I'm still going to submit my screenshots later, and I want to make sure the assistant that asked for them gets them.
- RFI4 years ago
Thank you rostaman whatever you went through to get through the LM_LICENSE_FILE environment variable problem would be helpful.
- rostaman4 years ago
Sure, glad to help if I can! I just posted my info for the assistant. Let's see what happens.
Hey RFI, I finally got it working! Before I only had the path to the subdirectory for my LM_LICENSE_FILE. I changed that to be the fully qualified filename of the license file. It still didn't work with the change to only the System environment variable, but after I modified the User one too, BOOM! Success!
Hope it works for you too, friend.- RFI4 years ago
Thanks I am not sure what you mean by "fully qualified name" can you post a screenshot? I was only adding an env variable to User variables, I will try system variable next.
