Questa 2 licenses?
Please use SALT_LICENSE_SERVER and delete the SALT_LICENSE_FILE.
Please use enabled and available mac address
Sheng thanks, but it still doesn't work.
I deleted the user variable SALT_LICENSE_FILE and restarted my system.
The system variable SALT_LICENSE_SERVER has a value of C:\altera_lite\Licenses. (This is a folder I made to put the license into.)
This folder contains one file called LR-154xxx_License.dat (LR-144xxx is the name of my computer).
From a command prompt, lmutil lmdiag says "Can't fetch the requested information! Kindly re-check the license file path and server details."
ipconfig /all states that Ethernet adapter Ethernet2 has a physical address of 84-5C-31-3F-xx-xx (I'm hiding the full address...). There are 3 other wireless LAN adapters listed, all are showing Media disconnected. So it is using the wired connection.
The contents of the LR-154xxx_License.dat file has correct MAC address. Here are some snips from the file.
This block is repeated with the same HOSTID, a different Altera SN, and different codes.
What can I try next?
- ShengN_altera5 months ago
Yes, you need to point to that specific .dat file
Does your problem resolved?
