12 years agoQuartusII Error: Please Help me.
this is the first time I use QuartusII: I'm a newbie with FPGA design. I have installed the Web Edition version 13.1 on a WindowsXP Pro 32bit (Athlon XP+2800, 2GB RAM + 2GB free hard disk space). When I open the project and select Processing->Start Compilation the "analysis and synthesis" completes without problems but the "Fitter (Place and Route) stops every time at 90% when the "post fitting delay annotation" is running and this error windows is displayed. The error says: *** fatal error: unrecognized windows exceptionmodule: quartus_fit.exe
stack trace:
0x13243: tbb::internal::generic_scheduler::get_task + 0x23
0x15020: tbb::internal::custom_scheduler<tbb::internal::intelschedulertraits>::local_wait_for_all + 0x220
0x56eae: tis_re_delay_tree_netlist::is_itt_starting_point + 0x1b0e
0x14fe6: tbb::internal::custom_scheduler<tbb::internal::intelschedulertraits>::local_wait_for_all + 0x1e6
0x56836: tis_re_delay_tree_netlist::is_itt_starting_point + 0x1496
0x54117: tis_re_delay_tree_netlist::tis_re_delay_tree_netlist + 0x4e7
0xa6a4: tapi_root_impl::annotate_atom_netlists_post_fit + 0x234
0xc22e: tapi_root_impl::annotate_all_iterms + 0xae
0x71a8: tapi_root_impl::start + 0x368
0x7994: tapi_root_impl::start + 0x64
0xa4333: fitcc_tdc_utility::initialize_dat + 0x2b3
0xa482d: fitcc_tdc_utility::setup_tdc_utility + 0x9d
0xa6552: fitcc_tdc_utility::fitcc_tdc_utility + 0x1d2
0x38f7e: fitcc_env::get_tdc_utility_or_create_if_necessary + 0x30e
0x1c12a6: fsac_auto_delay_chain_op::work_new + 0x1c6
0x1abe4f: fsac_delay_chain_op::work + 0x22f
0x7db9: fcuda_expert::fitter_post_operations + 0x1b9
0x404ad: fitcc_expert::fitter_post_operations + 0x1ad
0x41e8e: fitcc_expert::invoke_fitter + 0x88e
0x5052: _fcuda_execute + 0x1f2
0xa52c: fmain_start + 0x6ac
0(continued in attached text file) This error happens also with project examples on the DE0 board CD from Terasic so this isn't a problem caused by my project but it's caused by my computer (hardware requirements or Windows configuration). Can anyone help me? Best regards.
