quartus/eda/sim_lib/mentor/cyclone10gx_hssi_atoms_ncrypt.v(40): (vlog-2163) Macro `<protected> is un
- 1 year ago
Hello Sheng,
This appears to most likely be a problem with my computer: I am running Ubuntu 22.04.
The files compile fine if I install questa in a docker container running Ubuntu 22.04, just not on my desktop. I wondered if it might be a difference in gcc, but gcc -v returns the same thing on the bad computer and on the docker container: gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04).
I will ask Siemens if there is anything that might cause this to go wrong.
Can you give any insight on what's on line 40? This and the other _ncrypyt.v files from Quartus and Quartus Pro behave the same way (e.g. fiftyfivenm_atoms_ncrypt.v, cyclonev_atoms_ncrypt.v), but all of my plaintext source files work OK.
Gavin
Hello Sheng,
I started by using the attached msim_setup.tcl script generated by Platform Designer from the attached .qsys project testbench (the forum doesn't allow .qsys or .tcl, so rename qsys_test_qsys.xml to qsys_test.qsys msim_setup_tcl.txt to msim_setup.tcl).
I believe Platform Designer always populates these lines in the dev_com alias for Cyclone 10 GX designs:
eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclone10gx_atoms_ncrypt.v" -work cyclone10gx_ver
eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclone10gx_hip_atoms_ncrypt.v" -work cyclone10gx_hip_ver
eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclone10gx_hssi_atoms_ncrypt.v" -work cyclone10gx_hssi_ver
Gav
