11 years agoHello Ted,
thanks a lot again for your support. Sorry for my questions, but for a newbie its hard to get started. Your design worked well and in the meantime, I recognized, that I didnt`t see the "Transcriptor" Window in Modelsim. But now, i got more information. Modelsim stopped the simulation with an error, because a file called "../../rtl_work.filename" could not be found. The file isn`t in the directory, so how to create this file? And let me ask you, what exactly do you mean with "modify it to add clk/reset generation". Is it to add a clock and a reset from the IP catalog? For your information, actually i receive the clock from an external signal, so i just got an input port. In the waveform editor, you could generate a clock. Is it possible to work like that in Modelsim to or is it necessary to use the IP blocks as mentioned in my question above? Thank you in advance.
