11 years agoHey Ted,
thank you for the reply. It simply doesn`t work using the description. My steps: 1. Check if the design is compileable. 2. File -> Create/Update -> Create HDL Design File from current design --> so i receive a .v File. After that, i follow the steps we already discussed and use the .v file as "test bench file". Running RTL Simulation, ModelSim opens but no wave files or something else in the project.
