17 years agoQuartus v7.2 & 8 together?
Is anyone using these two versions on the same machine?
I've run into several problems attempting to do so. So far I've had to: * manually rename 3 environment variables * change a path in SOPC builder * manually rename the v7.2 directory so NIOS EDS can't find it. It's a real PITA, and I still can't be sure that everything is building in v8 using the right components. And I'm not looking forward to having to switch back to v7.2 for legacy projects.
