17 years agoYou don't have compiz or any other sort of "eye candy" enabled, do you? If so, I think you need to disable that. (Good luck disabling compiz...in my experience it's easy to install/enable and a "right pain" to disable...!) Otherwise, check to make sure that the environment setup is actually correct....what works for me, might not for you.
Also, you can try debugging the shell/Perl scripts that wrap the call to Java that the SOPC Builder GUI requires. My guess is that you'll be able to learn more by taking this route than anything else. Please do post your results, as I'm always a capable UNIX debug guy. Cheers, and Good luck! - uraslacker
