17 years agoAny new suggestions? I have two 8.04 boxes... one reports a "Cannot open X display "(not specified)". when I try to run quartus, the other just hangs....
I should clarify... after all my trouble with 8.04 I performed a clean re-install - and I still have the same symptoms where the machine just hangs. The other machine is my personal laptop - and it has the "X display" problem. So far Quartus is the only EDA tool I'm using that doesn't work in Ubuntu 8.04 - Modelsim works fine. : (
