17 years agoQuartus II uses MainWin (...thus, the /tmp/Mw.... stuff). You could try running mwcleanup and/or just deleting/removing all of the "/tmp/Mw*" directories. Also, knowing how MainWin works, you might also want to check that you have the following font packages installed:
ii fontconfig 2.5.0-2ubuntu3 generic font configuration library - support
ii fontconfig-config 2.5.0-2ubuntu3 generic font configuration library - configu
ii gsfonts 1:8.11+urwcyr1.0.7~pre43-1 Fonts for the Ghostscript interpreter(s)
ii language-support-fonts-zh 1:8.04+20080229 Additional fonts metapackage for Chinese
ii libfontconfig1 2.5.0-2ubuntu3 generic font configuration library - runtime
ii libfontconfig1-dev 2.5.0-2ubuntu3 generic font configuration library - develop
ii libfontenc-dev 1:1.0.4-2 X11 font encoding library (development heade
ii libfontenc1 1:1.0.4-2 X11 font encoding library
ii libxfont-dev 1:1.3.1-2 X11 font rasterisation library (development
ii libxfont1 1:1.3.1-2 X11 font rasterisation library
ii msttcorefonts 2.4 Installer for Microsoft TrueType core fonts
ii texlive-fonts-recommended 2007-13 TeX Live: Recommended fonts
ii ttf-freefont 20060501cvs-12 Freefont Serif, Sans and Mono Truetype fonts
ii ttf-indic-fonts-core 1:0.5.0-0ubuntu1 Core collection of free Indian language font
ii ttf-malayalam-fonts 1:0.5.0-0ubuntu1 Free TrueType fonts for the Malayalam langua
ii ttf-unfonts-core 1.0.1-6ubuntu1 Un series Korean TrueType fonts
ii x-ttcidfont-conf 27 TrueType and CID fonts configuration for X
ii x11proto-fontcache-dev 0.1.2-4ubuntu1 X11 font cache extension wire protocol
ii x11proto-fonts-dev 2.0.2-5ubuntu1 X11 font extension wire protocol
ii x11proto-xf86bigfont-dev 1.1.2-4ubuntu1 X11 Big Fonts extension wire protocol
ii xfonts-100dpi 1:1.0.0-4 100 dpi fonts for X
ii xfonts-75dpi 1:1.0.0-4 75 dpi fonts for X
ii xfonts-base 1:1.0.0-5 standard fonts for X
ii xfonts-encodings 1:1.0.2-3 Encodings for X.Org fonts
ii xfonts-scalable 1:1.0.0-6 scalable fonts for X
ii xfonts-utils 1:1.0.1-2ubuntu1 X Window System font utility programs
ii xfonts-wqy 0.9.9-3 WenQuanYi Bitmap Song CJK font for X That's not because there's any particular requirement for exactly these font packages, but it is working for me and these are what I have installed. MW could be hanging when building up the font cache. Cheers and Good luck!
