17 years ago
Quartus system verilog interface parameter bug
Does anyone know of a workaround for the following System Verilog interface parameter bug?
The short version:
In some (not all) contexts, the default value of an interface parameter is used instead of the overriding value.
The very long version (offending code is attached):
Error message produced by following code:
Error (10232): Verilog HDL error at if_test.sv(44): index 4 cannot fall outside the declared range [3:0] for vector "io.in"
Observations of above message:
- The declared range of io.in is [7:0] not [3:0]
- The default paramater value of the interface would give a range for io.in of [3:0] as reported by the error message.
    What QII version are you using? If you delete the db directory, does the problem go away?
    --- Quote Start ---
    --- Quote End ---
    I am using QII 8.0. Deleting the db does not help. This behavior is consistent and repeatable.
    I am really just fishing for any workaround ideas that do not involve re-writing my entire design without interfaces.
    Turns out it's pretty trivial, but i'll post my workaround anyway.
    Simply making a wrapper module for the interface support works. If i just encapsulate the problem functionality in a module that does not use interfaces, then call this module from a wrapper that does use interfaces, it works.
    I've attached the updated test case, just for completeness.
