Quartus SSN Analyzer
It seems Quartus SSN Analyzer is no longer supported by Quartus Prime Pro? The menu is not there! Any idea what the status is? Is SSN Analyzer still supported by Quartus?
- AnttiLukats
I have Pro and Lite installed. In Pro it is not there. In Lite I see the menu item "SSN Analyzer" but it says I need paid subscription
So it is also not working. So I wonder what is needed to enable SSN in Lite? Pro License does not help. - sstrell
I will explain this one more time. I don't know how much clearer I can make it.
Lite and Standard are the same so the feature appears in both.
You can never use the feature in Lite. You must use Standard.
A paid subscription is required for Standard which would get you access to the feature.
The feature is not available in Pro and neither is MAX10 support.
Why is this so complicated?
- AnttiLukats
IO I see, so the SSN menu is simply WRONG in Lite and should not be there. I got it.
- AqidAyman_Altera
I’m glad that your question has been addressed. May I know is there any more help needed from you regarding this issue?
