quartus running the modelsim simulation failed
Determining the location of the ModelSim executable...
Using: C:\intelFPGA_lite\20.1\modelsim_ase\win32aloem
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off lab01 -c lab01 --vector_source="C:/DDDD/Waveform.vwf" --testbench_file="C:/DDDD/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition
Info: Copyright (C) 2020 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Sun Sep 28 14:16:02 2025
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off lab01 -c lab01 --vector_source=C:/DDDD/Waveform.vwf --testbench_file=C:/DDDD/simulation/qsim/Waveform.vwf.vt
Info (119006): Selected device 5CSEMA5F31C6 for design "lab01"
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory="C:/DDDD/simulation/qsim/" lab01 -c lab01
Info: Processing started: Sun Sep 28 14:16:03 2025
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory=C:/DDDD/simulation/qsim/ lab01 -c lab01
Info (204019): Generated file lab01.vo in folder "C:/DDDD/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4725 megabytes
Info: Processing ended: Sun Sep 28 14:16:03 2025
Info: Elapsed time: 00:00:00
Info: Total CPU time (on all processors): 00:00:01
**** Generating the ModelSim .do script ****
C:/DDDD/simulation/qsim/lab01.do generated.
**** Running the ModelSim simulation ****
C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/vsim -c -do lab01.do
Error.
This is all of the log file, same as you, I didn't see any error messages, so i really don't know what to do
