TMayd
3 years agoQuartus reporting unconstrained inputs and outputs on constrained paths
Hi I have implemented a set of timing constraints on my Arria 10 design and I'm confused about two things. [Running Quartus Pro 22.1] 1. Quartus is reporting one of my input clocks (it is a differ...
AqidAyman_Altera
3 years agoHi Tyler,
I think it is better to share the .qar design for this project in order for us to further investigate this and if it is potentially a bug, we need it to report to the engineering team. You no need to share the full design, it is sufficient to share the one that related to this issue only for us to reproduce the issue from our end. You can share the file through email for privacy. I will initiate the email first.
Aqid
