9 years ago
Quartus removes logic functionality
I started to use Quartus Prime 15.1.0 and DE0 Nano board. I want to try some functionality but Synthesis removes some blocks in the design and I do not know why.
Is there some possibility to see why some functionality is optimized out ?
Thank you for help.
Vaclav
    @Vaclav,
    Make sure the blocks outputs are used. By this I mean that the synthesizer will optimize away logic that it sees is not eventually providing a top-level output(pin).
    Check the warnings and see what gets removed. Then ensure that:
    1. Clocks are connected
    2. Design is NOT stuck in reset
    3. Outputs are connected.
    You may need to work backwards to work out whats causing the logic removal.
    Good point, thank you. I forgot to connect some signals on the top level. Is there any check in Quartus that some connections of the submodule are missing ?
