9 years agoQuartus removes logic functionality
Hello, I started to use Quartus Prime 15.1.0 and DE0 Nano board. I want to try some functionality but Synthesis removes some blocks in the design and I do not know why. Is there some possi...
9 years agoCheck the warnings and see what gets removed. Then ensure that:
1. Clocks are connected 2. Design is NOT stuck in reset 3. Outputs are connected. You may need to work backwards to work out whats causing the logic removal.
