17 years agoHi,
As you said, designers process each submodule separately each in its own directory. The top level is treated similarly in its own separate directory. But the top level is given path and the design files added as required. This is done in all cases of normal build and the idea of separate directories is important to avoid a mix-up of compilation products. The incremental compilation is a special case(very few people go for it) and means that once you compile a module you finished with it any further high when it is called up. The compiler doesn't have to recompile it while in normal build the compiler treats all the modules as one new design to be fitted freely.(logiclock is similar to some extent to incremental compilation). Incremetal compilation can be time saving but the fitter is constrained as the chip is filled up and may eventually fail to fit after all. edit: Two issues are worth noting: 1) if your lower level modules have same names in two different folders and you added them at the top, this will not guarantee trouble-free compilation. So name all modules uniquely across all folders. 2) when you archive then restore your project, all modules are dropped in the same one folder, quartus will not reverse the folder structure. kaz
