15 years ago
Quartus programmer stop at 80%
Hi:
I build the sof file without problem. somehow, when I program it to the board, the progress bar stops at 80%. It is cyclone iii 3c25f324 fpga. Is it related to any specific issue?
    no, I tried programming with the sof file built under 9.1 months ago and it is good. I updated to 10.0sp1. I noticed the LE 100% occupied. could it be a problem?
    Total combinational functions 21,403 / 24,624 ( 87 % )
    Dedicated logic registers 15,775 / 24,624 ( 64 % )
    Family Cyclone III
    Device EP3C25F324I7
    Timing Models Final
    Total logic elements 24,565 / 24,624 ( 100 % )
    Total registers 15933
    Total pins 128 / 216 ( 59 % )
    Total virtual pins 0
    Total memory bits 151,221 / 608,256 ( 25 % )
    Embedded Multiplier 9-bit elements 53 / 132 ( 40 % )
    Total PLLs 1 / 4 ( 25 % )
    --- Quote Start ---
    Any error msgs?
    --- Quote End ---
    There were some problems with the 10.0 programmer, I think I had to use an earlier version with a Cyclone II. They seem to have been fixed with 11.0.
    What windows are you using? And what version of Q(32/64bits)?
    Try using command line, go to nios 2 command shell, cd to your directory and do a nios2-configure-sof /your/sof/path
