Quartus Problems
I have been using Quartus II for quite a while maybe starting with 5.0 web edition. I have a problem that I always keep running into and maybe someone can help me out. The problem involves me getting erratic results. I have used cyclone II and cyclone devices on the trex and de2 boards from terasic. I don't believe that the chips or dev boards are at fault, I believe it is how I use the software. I have also used the software on a 5v MAX 7000 part and it was rock solid. I have never paid much attention to timing constraints and such. I just make my modules with Verilog and connect them together in a block diagram file adding pins and then compile. Most of the time things go fine, but sometimes I will add just one more element to the block diagram and everything will stop working - like no signals in or out of the chip! After unraveling what changed, I will be back in business. Can anyone please explain what might be going on here. Is it timing problems? Where would I find information on this kind of problem? Thanks in advance!
