Quartus Pro 22.3: Segment Violation
Problem Details
Error:
*** Fatal Error: Segment Violation: faulting address=(nil), PC=(nil) : 0:
Module: quartus_fit
Stack Trace:
Err Handler 0x136a4: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xe0 (ccl_err)
Err Handler 0x91d6c: msg_ie_get_call_stack(void*) + 0xc4 (ccl_msg)
Err Handler 0x93cd2: MSG_INTERNAL_ERROR::report_fatal(char const*, void*, bool) + 0x40 (ccl_msg)
Err Handler 0x170b1: err_report_fatal_exception(char const*, void*, bool) + 0x60 (ccl_err)
Err Handler 0x17351: err_sigaction_handler + 0x191 (ccl_err)
System 0x12cf0: (pthread)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: AlmaLinux release
OS version: 8
Quartus Prime Information
Address bits: 64
Version: 22.3.0
Build: 104
Edition: Pro Edition
We had critical crashes after only 5min using 22.4. Parallel synthesis is broken.
Quartus lacks regressions tests, so advising to use a more recent version isn't appropriate to solve any issues unless listed in the release notes as solved.
An IPS case has been opened for it.
- RichardT_altera
Try to upgrade the design to the latest Quartus version 22.4 to check if the issue persists.
Could you help to share your design .qar file (Project > Achieve Project, to generate .qar file) that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
Do let me know if the design can't be shared publicly, I will send you an email on transfer the file securely.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
- alexislms
Contributor
- RichardT_altera
Understandable, since an IPS case has been created, I will now transition this thread to community support.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey
