alexislms
Contributor
3 years agoQuartus Pro 22.3: Segment Violation
Problem Details Error:
*** Fatal Error: Segment Violation: faulting address=(nil), PC=(nil) : 0: Module: quartus_fit Stack Trace: Err Handler 0x136a4: ERR_UNWINDER_BACKTRACE::get_stack_trace(v...
- 3 years ago
We had critical crashes after only 5min using 22.4. Parallel synthesis is broken.
Quartus lacks regressions tests, so advising to use a more recent version isn't appropriate to solve any issues unless listed in the release notes as solved.
An IPS case has been opened for it.
alexislms
Contributor
3 years agoWe had critical crashes after only 5min using 22.4. Parallel synthesis is broken.
