alexislms
Contributor
4 years agoQuartus Pro 22.2: enum logic vs logic : Error(16983): arrays have different elements
module tb;
enum logic [7:0] {A, B, C} fsm [4];
logic [7:0] state [4];
assign state = fsm;
endmodule
Never had an issue with Vivado and never had an issue with Modelsim: https://www.edapl...
- 4 years ago
Yes, there is a plan to fix this but it may takes time and I do not have the exact detail on when it will be fix. As this is subject to change.
RichardT_altera
4 years agoA workaround suggested by the engineering team is to change RTL a little bit.
By changing the assignment of unpacked type to bit by bit instead of complete.
for the given design example
module tb;
assign state[0] = fsm[0];
assign state[1] = fsm[1];
assign state[2] = fsm[2];
assign state[3] = fsm[3];
//assign state = fsm;
endmodule
The engineering team will check with the tool vendor on fixing this issue.
