ThomasH's avatar
ThomasH
4 years ago
Quartus Prime Standard 20.4 silent installation with SCCM
When deploying Intel FPGA 20.4 standard we run into an issue when attempting to install the software as required. The install will just hang up with no error message while running the Quartus installer. When we set the deployment to available it is able to successfully install.
Install commands
QuartusSetup-20.1.1.720-windows.exe --mode unattended --unattendedmodeui none --installdir C:/intelFPGA/20.1 --accept_eula 1
We saw that this issue was also reported in 19.1, but it doesn't look like a resolution was found.
https://community.intel.com/t5/Intel-FPGA-Software-Installation/Quartus-Prime-Standard-19-1-silent-installation-with-SCCM/m-p/719876/highlight/true#M1660
Any recommendations would be greatly appreciated.
  • Hi Thomas,
    I've spent 2 months fighting this myself and had a breakthrough. It seems that the Quartus installer uses 'Bitrock', and installer technology I have also been fighting when trying to install Microchip's MPLAB X IDE 5.5.
    Long story short, this forum post helped: https://docs.microsoft.com/en-us/answers/questions/397336/different-behaviour-required-vs-available-applicat.html
    Use the checkbox on the Programs tab of the Deployment Type, to 'Run installation and uninstallation as 32bit on 64 bit clients'. Once I ticked that, my script actually managed to install quartus on a couple of machines last night.
    I've written a long winded powershell script that pre-installs the usb blaster drivers (and puts their certs in machine trusted), installs quartus, then modelsim, then the patch for 20.1, and finally does the firewall entries for the right bits.
    The command line that now works as 32 bit process is:
    23/09/2021 05:43:43 Started Step2 Install
    Executing 'C:\WINDOWS\ccmcache\36\app\QuartusSetup-20.1.1.720-windows.exe --mode unattended --unattendedmodeui none --installdir "C:\Program Files\IntelQuartusV20" --accept_eula 1' at 23/09/2021 05:43:43
    23/09/2021 05:49:35 finished Step2 Install
    Have a go with that, hope it helps. It's been driving me up the wall for years since Intel took this over.
    Doug.
  • Hi @ThomasH ,
    Could you try @DougBarry solution and validate whether it works for you?
    Richard Tan
  • ThomasH's avatar
    ThomasH
    Thank you Doug and Richard,
    The fix Doug recommended worked and I'm seeing successful installs. Thank you Richard for your continued diligence in troubleshooting this issue I really appreciated it.
  • Hi @ThomasH
    I am glad that the workaround works for you.
    Before I close this case, could I get your help to try to install Quartus Pro v21.3, without the 'Run installation and uninstallation as 32bit on 64 bit clients' enabled? The Quartus Pro 21.3 is scheduled to release by next week.
    Richard Tan
  • ThomasH's avatar
    ThomasH
    Of course, once I see the new release I'll test it out.
  • Hi @ThomasH
    Quartus Pro 21.3 software has been released today. Please help to test it out whether it still stuck during the silent installation, without the 'Run installation and uninstallation as 32bit on 64 bit clients' enabled.
    Richard Tan
  • Hi @ThomasH
    Do you able to install the Quartus Pro 21.3?
    If the installation hang/fail, please help to share the installation log and debug log so we could look into this.
    QuartusSetup-21.3.0.170-windows.exe --mode unattended --unattendedmodeui none --installdir C:/intelFPGA/21.3 --accept_eula 1 --parallel-decompression-cores 1 --syncdebugtrace debug-1-core.txt
    Richard Tan
    • RichardT_altera's avatar
      RichardT_altera
      Hi @ThomasH
      Any update on this?
      Richard Tan
  • ThomasH's avatar
    ThomasH
    Hi Richard, unfortunately we're running into other issues with the new installer. This may be because we've used the standard install in the past and 21.3 currently only has the pro version available.
      RichardT_altera
      Hi @ThomasH
      May I know what is the issue about?
      Is the Quartus Pro 21.3 installed successfully?
      Richard Tan
  • Hi @ThomasH
    May I know what is the issue that you face with the new installer?
    Is the Quartus Pro 21.3 software able to installed successfully?
    Richard Tan
  • ThomasH's avatar
    ThomasH
    Sorry it took a while to find the time to test it out. It's no longer a problem with the newest installer.
  • Canarello's avatar
    Canarello
    Based on your install commands, it looks like you've set up the unattended mode correctly. However, since it's hanging up without any error messages, it might be challenging to pinpoint the exact issue.
    One thing you could try is to enable logging during the installation process. Adding the --logfile <path_to_log_file> option to your install command will create a log file that might provide more details about what's going wrong.
    For more detailed guidance on troubleshooting silent installations with SCCM, you might find this article useful: https://learnmesccm.com/ts/deploy-sccm-task-sequence.html. They often provide step-by-step instructions and best practices for deploying software with SCCM.
