Quartus Prime Standard 20.4 silent installation with SCCM
- 5 years ago
Hi Thomas,
I've spent 2 months fighting this myself and had a breakthrough. It seems that the Quartus installer uses 'Bitrock', and installer technology I have also been fighting when trying to install Microchip's MPLAB X IDE 5.5.
Long story short, this forum post helped: https://docs.microsoft.com/en-us/answers/questions/397336/different-behaviour-required-vs-available-applicat.html
Use the checkbox on the Programs tab of the Deployment Type, to 'Run installation and uninstallation as 32bit on 64 bit clients'. Once I ticked that, my script actually managed to install quartus on a couple of machines last night.
I've written a long winded powershell script that pre-installs the usb blaster drivers (and puts their certs in machine trusted), installs quartus, then modelsim, then the patch for 20.1, and finally does the firewall entries for the right bits.
The command line that now works as 32 bit process is:
23/09/2021 05:43:43 Started Step2 Install
Executing 'C:\WINDOWS\ccmcache\36\app\QuartusSetup-20.1.1.720-windows.exe --mode unattended --unattendedmodeui none --installdir "C:\Program Files\IntelQuartusV20" --accept_eula 1' at 23/09/2021 05:43:43
23/09/2021 05:49:35 finished Step2 Install...
Have a go with that, hope it helps. It's been driving me up the wall for years since Intel took this over.
Doug.
Hi @ThomasH
I don't think the debug-1-core.txt file that you provided is the one that we need.
The installation log files are in <installdir>/logs directory. They should be in text files.
Could you help to confirm this and send us the installation log?
Richard Tan
The only log I found is quartus_help-20.1.1.720-windows-install.log, located in C:\intelFPGA\20.1\logs and contains the following
Log started 09/15/2021 at 01:40:47
Preferred installation mode : unattended
Trying to init installer in mode unattended
Mode unattended successfully initialized
Preparing to Install
Unpacking files
Installation completed
Log finished 09/15/2021 at 02:16:39
Exiting with code 0
- RichardT_altera5 years ago
Hi @ThomasH
It seems to me that the installation was completed.
Could you help to check whether it was installed?
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - ThomasH5 years ago
Unfortunately it did not install
Do you see anything like C:\intelFPGA\20.1\quatus\common\help ?
The help folder directory is the one that is being installed.
Richard Tan
