Quartus Prime software (18.1) quit unexpectedly
- 3 years ago
The "99.64% utilization..." statement was based on the 2019 design.
The person who contacted Intel at that time was named Nathanael Huffman.
I have also attached the 2019 design for your reference.
Based on this information, my takeaway point is that the .INI file, provided in my previous reply, is derived from the 2019 design and should be safe to use in your current project. It has previously been verified by the engineering team in 2019.
Richard Tan
Wait a sec, I have found in the database that the design reviewed is indeed the same as yours. It was filed in the IPS case back in 2019. Does that ring a bell? It seems that some information may have been lost or overlooked over time.
Regarding what the issue was, I quoting what the engineering saying directly:
"When the clustering is computing utilization on a converged clustering solution, it sees a 99.64% utilization on the full chip. This is less than 100%, so there should be no over-utilization; However, the code assume that anything < 1.0 (eps=0.01) as the rule to filter out over-utilization regions, so that means any regions with >99% utilization counts as overflow and lead to bad things downstream. "
Last time, the engineering team confirmed that this issue does not exist in the Quartus Pro v19.1. Therefore, you may consider upgrading your design to Pro, which will provide you with peace of mind.
Richard Tan
- mtrovato13 years ago
Post erased
Hello Richard,
after talking to my colleagues I have additional questions.
When you say 99.64% utilization do you mean that you actually compiled the project that I shared with you and you see that amount of CPU utilization? If so, I would like to share with you the original design that does not need the quartus.ini patch and kindly ask you to compile that too so you can tell me the peak utilization that you see.
Moreover, who was the person who contacted you in 2019 for this design? Do you have a pointer for that? Knowing that would help follow up on that.
Unfortunately I do not have the green light to upgrade to 19.1
Marco
