Quartus Prime software (18.1) quit unexpectedly
- 3 years ago
The "99.64% utilization..." statement was based on the 2019 design.
The person who contacted Intel at that time was named Nathanael Huffman.
I have also attached the 2019 design for your reference.
Based on this information, my takeaway point is that the .INI file, provided in my previous reply, is derived from the 2019 design and should be safe to use in your current project. It has previously been verified by the engineering team in 2019.
Richard Tan
I could not find this internal error in the database. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
Prior that, try to upgrade/migrate the design to the latest Quartus Standard version 22.1 to check if the issue persists, as a lot of bug has been fixed since then.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
