9 years agoQuartus Prime Programmer JTAG Error Codes
I am attempting to program a 10M50DCF with a Quartus Prime Programmer and a USB Blaster via JTAG. I have loaded the proper drivers, setup the hardware, and loaded my .pof. When I hit Start I get the following message: 209053 Unexpected error in JTAG server -- error code 35. Where can I find the definition of the numerical error code? Thank you, Keith2 Replies
Hey Keith,
I do not think that Altera has the definition of the numerical error code. If anyone has it, I am more than happy if you guys can share :-D Back to your board, are you able to auto detect your JTAG chain? Is .sof programming working for you? Regards, Vinhael - Altera_Forum
Thanks for the quick reply Vinhael.
I was unable to auto detect the device in the JTAG chain. This led to a discovery that the pinout for the programming header on the board did not match the USB blaster. I was able to correct this and the device programmed as expected. I would still be interested in a document that covers the error codes if anyone has it. Thanks! - Keith
