Quartus Prime Pro fatal error
- 7 months ago
I don't find this IE in the database.
I believe the issue is resolved in Quartus 25.3.1, so I suggest upgrading the design to 25.3.1 in order to fix the problem.
Out of curiosity, does the same issue occur with other devices, e.g., Arria 10?
If yes, could you share the QAR project (Project > Achieve Project) so we could investigate it further?
Richard Tan
I know that 25.3 Pro generally works for Agilex 3. If you can't track down the error to specific IP or design constructs, Altera support should get a project .qar to locate the problem. Latest Quartus version supporting Agilex is 25.3.1 Pro b.t.w. May be it makes a difference.
Frank
- AnttiLukats7 months ago
I got the projects migrated and working somehow. So it all works now, dont know why it failed first.
- RichardT_altera7 months ago
Richard Tan
