AnttiLukats
7 months agoQuartus Prime Pro fatal error
Hi when we click compile, internal error comes: Problem Details Error: Internal Error: Sub-system: RDB, File: /quartus/db/rdb/rdb_utility.cpp, Line: 1944 rval == nullptr Stack Trace: Quartus 0x10...
- 7 months ago
I don't find this IE in the database.
I believe the issue is resolved in Quartus 25.3.1, so I suggest upgrading the design to 25.3.1 in order to fix the problem.
Out of curiosity, does the same issue occur with other devices, e.g., Arria 10?
If yes, could you share the QAR project (Project > Achieve Project) so we could investigate it further?
Richard Tan
AnttiLukats
7 months agoThe patch didnt fix it. Same project with Agilex-5 device settings compiles, where running with Agilex-3 errors out :( so problem not fixed with patch
