DaveMM's avatar
DaveMM
1 year ago
Quartus Prime Pro: Adding signaltap causes crash
Running with Quartus Prime Pro 22.3.
Device: 1SG280LU2F50E2VG
Quartus will compile the design successfully without signaltap.
Quartus will crash and create file "assert.0.sta_debug_netlist.dot.qz" when signaltap is added.
  • DaveMM's avatar
    DaveMM
    Unfortunately, this is the kind of support I've come to expect from Intel. Complete silence.
  • DaveMM's avatar
    DaveMM
    Here are more details:
    Problem Details
    Error:
    Internal Error: Sub-system: STA, File: /quartus/tsm/sta/sta_graph.h, Line: 393
    Bad fanin count: Old count: 3, Total count: 2, Level: 20. Node: [870315]<instance deleted from post by me>
    Stack Trace:
    Quartus 0x534f90: STA_NODE::increase_fanin_completed_count(unsigned long) + 0x270 (tsm_sta)
    Quartus 0x631e5a: tbb::interface9::internal::do_iteration_task<QTL::parallel_do_chunked_no_serial_attempt<10, __gnu_cxx::__normal_iterator<STA_NODE**, std::vector<STA_NODE*, std::allocator<STA_NODE*> > >, STA_TRAVERSAL_MANAGER::do_clock_traversal()::{lambda(STA_NODE*, QTL::FeederProxy<10, STA_NODE*>&)#5}>(__gnu_cxx::__normal_iterator<STA_NODE**, std::vector<STA_NODE*, std::allocator<STA_NODE*> > >, STA_TRAVERSAL_MANAGER::do_clock_traversal()::{lambda(STA_NODE*, QTL::FeederProxy<10, STA_NODE*>&)#5}, STA_TRAVERSAL_MANAGER::do_clock_traversal()::{lambda(STA_NODE*, QTL::FeederProxy<10, STA_NODE*>&)#5})::{lambda(QTL::TBB_ITEM_GROUP<STA_NODE*, 10>, tbb::interface9::parallel_do_feeder<QTL::TBB_ITEM_GROUP>&)#1}, QTL::TBB_ITEM_GROUP>::execute() + 0x35a (tsm_sta)
    Quartus 0x26bdd: tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 0x75d (tbb)
    Quartus 0x2064e: tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 0x1ce (tbb)
    Quartus 0x1f1cb: tbb::internal::market::process(rml::job&) + 0x1b (tbb)
    Quartus 0x1babd: tbb::internal::rml::private_worker::run() + 0x4d (tbb)
    Quartus 0x1bcd9: tbb::internal::rml::private_worker::thread_routine(void*) + 0x9 (tbb)
    System 0x7aa1: (pthread)
    System 0xe8c4d: clone + 0x6d (c)
    End-trace
    Executable: quartus
    Comment:
    None
    System Information
    Platform: linux64
    OS name: Red Hat
    OS version: 6
    Quartus Prime Information
    Address bits: 64
    Version: 21.4.0
    Build: 67
    Edition: Pro Edition
  • DaveMM's avatar
    DaveMM
    Sorry, I wasn't clear. I have tried quartus 21.4 and 22.3 (on a different server) and they both exhibit this problem.
    • sstrell's avatar
      sstrell
      What OS was on the machine that had 22.3?
  • We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
    Please be assured that we are doing everything we can to resolve this as quickly as possible. This will take some time, and we appreciate your patience and understanding during this period of time. Your case will be attended by AE soonest possible.
    Thank you again for your patience and understanding, and we are committed to provide you with the best possible support.
