ELIT1
2 years agoQuartus Prime Pro 24.1 RAM Inference problems
When trying to infer Block-RAM from the attached System Verilog code the following problems occurred: 1 - when used 'rd_outcken' input (RDOUTCKEN_USED = "YES") - out registers not packed to memory ...
KennyT_altera
2 years agoHi, I manage to download your design to take a look.
One way to understand what are the RAM supported setting is by pulling out the IP from the IP catalog. Set whatever setting that you want and generate out the IP. From there, you can copy out the generated output content of the IP to your design to see what is actually supported.
I attached a screenshot for you to refer. Thanks
- KennyT_altera2 years ago
Screenshot attached
