10 years ago
Quartus Prime not allowing apparently correct I/O assignment
Hi, I'm using Quartus Prime 15.1 and trying to program the DECA evaluation board. I've used a file provided by them to do the pin assignments. I am completely sure that I have used the correct one. When I compile, the Analysis and Synthesis runs just fine. However, the fitter keeps giving the following errors:
Error (169235): I/O bank 8 cannot select VCCIO of 1.2V which is required for pin LED[0] with I/O standard 1.2
Error (169193): VCCIO 1.2V is not compatible with the VCCIO requirement of the I/O bank 8 imposed by the selected configuration scheme
It shows the same thing for LED[1] which I am also using, which connects to a green LED on the board. One possible lead: the device that I select is 10M50DAF484C6GES, but I keep getting the following message: Info (253020): Default device 10M08DAF484C8G is automatically selected for the device family MAX 10. This message displays as soon as the device is selected when creating a new project.
Can anyone explain why this might be happening? Thanks!
Edit: never mind about that default device message, that comes when I select the MAX 10 family prior to selecting the specific device
    This means you have an incompatible set of I/O standards connected to bank 8. You need to consider what other I/O is connected to bank I/O and ensure they are all 1.2V I/O standards.
    I appreciate you state you've used a set of pin assignments provided by Arrow. However, there is clearly something wrong with it - these example files have been known to be wrong in the past. Post your project's .qsf file here and we can have a look.
    Cheers,
    Alex
    Hi a_x_h_75,
    so i can use different standards as long as they are all signed with the same VCCIO, right?
    Greets
    Jérôme
    Yes. You can use different I/O standards as long as they're all 1.2V.
    Cheers,
    Alex
    Hi all,
    I have encountered the same error today. I should start out by saying that Arrow's Tcl script works as intended, there is an additional important step in the tutorial I was following.
    For your config file to match the hardware of the DECA board you have to change a few more options.
    Go To: Assignments -> Device -> Device and Pin Options -> General
    There UNTICK "Enable nCONFIG, NSTATUS, and CONF_DONE pins"
    This will allow you to set the bank 8 I/Os to 1,2V.
    For the DECA board you should also UNTICK the rest of the config options int the same window:
    Auto-restart configuration after error
    Release clears before tri-states
    Enable device-wide reset (DEV_CLRn)
    Enable device-wide output enable (DEV_OE)
    Enable nCONFIG, nSTATUS, and CONF_DONE pins
    Enable JTAG pin sharing
    Enable CONFIG_SEL pin
    Leave "Auto usercode" enabled
