10 years agoQuartus Prime not allowing apparently correct I/O assignment
Hi, I'm using Quartus Prime 15.1 and trying to program the DECA evaluation board. I've used a file provided by them to do the pin assignments. I am completely sure that I have used the correct one. W...
9 years agoHi all,
I have encountered the same error today. I should start out by saying that Arrow's Tcl script works as intended, there is an additional important step in the tutorial I was following. For your config file to match the hardware of the DECA board you have to change a few more options. Go To: Assignments -> Device -> Device and Pin Options -> General There UNTICK "Enable nCONFIG, NSTATUS, and CONF_DONE pins" This will allow you to set the bank 8 I/Os to 1,2V. For the DECA board you should also UNTICK the rest of the config options int the same window: Auto-restart configuration after error Release clears before tri-states Enable device-wide reset (DEV_CLRn) Enable device-wide output enable (DEV_OE) Enable nCONFIG, nSTATUS, and CONF_DONE pins Enable JTAG pin sharing Enable CONFIG_SEL pin Leave "Auto usercode" enabled
