SMore11
7 years agoQuartus Prime Lite stuck during compilation (analysis & synthesis step)
Hello, I have troubles when I compile a project of mine on Quartus Prime Lite 18.0 with, as target FPGA device, a MAX10 (10M08DAF256C8GES). The compiler is stuck during the elaboration of a componen...
Karlis_Susters
4 years agoI had the exact same analysis and synthesis stuck on 47% issue, I solved it by setting "Allow register merging" to "Off" in Compiler settings -> advanced synthesis settings.
If that doesn't work, might be worth literally toggling every synthesis setting on that page and seeing if that works. Then narrow it down to the one setting that causes the problem by toggling a half, then a quarter, ...
Karlis
TheGil
2 years agoThis works for me! Thank you
