SMore11
7 years agoQuartus Prime Lite stuck during compilation (analysis & synthesis step)
Hello, I have troubles when I compile a project of mine on Quartus Prime Lite 18.0 with, as target FPGA device, a MAX10 (10M08DAF256C8GES). The compiler is stuck during the elaboration of a componen...
sstrell
7 years agoI seriously doubt that a MAX 10 design would be the cause here. If you were compiling for a top-of-the line Stratix 10 device, then certainly.
Can you post your code? What is the difference between the version that successfully compiled and the version that is not compiling?
