CFurr1
6 years agoQuartus Prime Lite Platform Designer Failed to find module error
Hi I am new to Quartus and FPGAs. I am trying to use the Platform Designer and create a NIOS2 simple system but when I go to generate the HDL I get an error of failed to find module. I have tried dif...
MEIYAN_L_Intel
6 years agoHi,
I have tried this system connection in Quartus Prime Pro 19.3 and the system is not allowed to connect data master to on-chip memory s1 and avalon mm pipeline bridge s0. But in your picture show no error with this connection.
I had reported this issue to the developer.
Also, I had tried to used Quartus Prime Lite v18.1 to connect the system in Platform Designer as well. It does not show the error with failed to find module.
May you try to revert back to Quartus Prime Lite v18.1?
- CFurr16 years ago
Thanks for all your help. I did try version 18 and it has worked so far without error. Thanks.
