CFurr1
6 years agoQuartus Prime Lite Platform Designer Failed to find module error
Hi I am new to Quartus and FPGAs. I am trying to use the Platform Designer and create a NIOS2 simple system but when I go to generate the HDL I get an error of failed to find module. I have tried dif...
MEIYAN_L_Intel
6 years agoHi,
For the Quartus Prime Lite edition is not required license file.
I had try to generate HDL for a system with with step as below:
1. New Project (in Quartus)
2. Open PLatform Designer
3. Connect the system with clock source and Avalon-MM clock crossing bridge
4. Generate HDL
It is successfully generate.
May I have the full error message for further investigate?
- CFurr16 years ago
[image: Screenshot at 2019-12-31 10:58:26.png] [image: Screenshot at 2019-12-31 10:58:51.png] Here are some screen shots of the Platform Builder. It seems that not matter what module I connect to the NIOS-II CPU it can't find that module. I have tried FIFO's JTAG-UART, PIO, SRAM.... all have the same error of can't find the module. Thanks -Clint
