Wavelength's avatar
Wavelength
5 years ago
Quartus Prime Lite no Slew Rate Setting?
I am working on a design in Quartus Prime Lite for a MAX-V CPLD.
I have everything compiling and spent a couple hours setting the IO types, current and pin#s but I don't see anywhere to the set the Slew Rate that is mentioned in the data sheets, handbook and other documents in the Lite software.
I see video's from college classes showing it but I don't see or able to enable that option in the Pin Planner.
Do I really need to spend $3000 to get that option?
Gordon
  • Ok, right clicking, then customize, then add Slow Slew Rate.
    Gordon
  • sstrell's avatar
    sstrell
    You can use the Assignment Editor or right-click in the All Pins list in Pin Planner and select Customize Columns to display additional assignments.
    • Wavelength's avatar
      Wavelength
      Thanks for the quick response!
      But there is no slew rate option in either one the Pin Planner or Assignment Editor. If I right click in the pin planner all the options are enabled and there is no options for Slew Rate in the Lite version.
      Gordon
  • sstrell's avatar
    sstrell
    So in Customize Columns, there's no option for slew rate?
      Wavelength
      Gordon
