Wavelength
5 years agoQuartus Prime Lite no Slew Rate Setting?
I am working on a design in Quartus Prime Lite for a MAX-V CPLD.
I have everything compiling and spent a couple hours setting the IO types, current and pin#s but I don't see anywhere to the set the...
- 5 years ago
Ok, right clicking, then customize, then add Slow Slew Rate.
Gordon
sstrell
5 years agoYou can use the Assignment Editor or right-click in the All Pins list in Pin Planner and select Customize Columns to display additional assignments.
Wavelength
5 years agoThanks for the quick response!
But there is no slew rate option in either one the Pin Planner or Assignment Editor. If I right click in the pin planner all the options are enabled and there is no options for Slew Rate in the Lite version.
Gordon
