Quartus Prime crashes when fitting/routing Arria 10 design with PCIe IP
i am currently using Quartus Prime 22.1 to synthesize a design for Arria 10 containing two PCIe IP. Whenever one or both of these PCIe IP are in the design, the fitter crashes soon after starting routing. Because i have to work on a secure network without internet connection i can only provide the information about the crashes like this:
Quartus Prime Standard 22.1 (licensed):
Problem Details Error: Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_route_lookahead.c, Line: 4322 Internal Error Stack Trace: 0x5d3090: vpr_qi_jump_to_exit + 0x80 (fitter_vpr20kmain) 0x106a4a: vpr_exit_at_line + 0x8a (fitter_vpr20kmain) 0x439eba: l_compute_and_cache_block_downstream_costs + 0x13da (fitter_vpr20kmain) 0x431606: aa_route_lookahead_setup_cached_lookahead_constants + 0x556 (fitter_vpr20kmain) 0x3ca85f: l_perform_pre_connection_operations + 0x26f (fitter_vpr20kmain) 0x3ca39f: l_route_to_target + 0x21f (fitter_vpr20kmain) 0x3c9c15: l_route_net + 0x4f5 (fitter_vpr20kmain) 0x3c4faf: aa_route_alg_route_all_nets + 0x21f (fitter_vpr20kmain) 0x45da1a: l_rt_prl_worker + 0xca (fitter_vpr20kmain) 0x629761: l_thread_start_wrapper + 0x41 (fitter_vpr20kmain) 0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x18210: mem_thread_wrapper + 0x70 (ccl_mem) 0x2854: thr_thread_begin + 0xa4 (ccl_thr) 0x17613: BaseThreadInitThunk + 0x13 (KERNEL32) 0x526b0: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 22.1std.0 Build: 915 Edition: Standard Edition
Quartus Prime Standard 22.1.1 (unlicensed, used trial version for synthesis to check if version upgrade would solve the problem)
Problem Details Error: Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_route_lookahead.c, Line: 4322 Internal Error Stack Trace: 0x5d30a0: vpr_qi_jump_to_exit + 0x80 (fitter_vpr20kmain) 0x106a4a: vpr_exit_at_line + 0x8a (fitter_vpr20kmain) 0x439eba: l_compute_and_cache_block_downstream_costs + 0x13da (fitter_vpr20kmain) 0x431606: aa_route_lookahead_setup_cached_lookahead_constants + 0x556 (fitter_vpr20kmain) 0x3ca85f: l_perform_pre_connection_operations + 0x26f (fitter_vpr20kmain) 0x3ca39f: l_route_to_target + 0x21f (fitter_vpr20kmain) 0x3c9c15: l_route_net + 0x4f5 (fitter_vpr20kmain) 0x3c4faf: aa_route_alg_route_all_nets + 0x21f (fitter_vpr20kmain) 0x45da1a: l_rt_prl_worker + 0xca (fitter_vpr20kmain) 0x629771: l_thread_start_wrapper + 0x41 (fitter_vpr20kmain) 0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x18210: mem_thread_wrapper + 0x70 (ccl_mem) 0x2854: thr_thread_begin + 0xa4 (ccl_thr) 0x17613: BaseThreadInitThunk + 0x13 (KERNEL32) 0x526b0: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 22.1std.1 Build: 917 Edition: Standard Edition
Quartus Prime Standard 22.1.2 (unlicensed, used trial version for synthesis to check if version upgrade would solve the problem)
Problem Details Error: Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_route_lookahead.c, Line: 4322 Internal Error Stack Trace: 0x5d30a0: vpr_qi_jump_to_exit + 0x80 (fitter_vpr20kmain) 0x106a4a: vpr_exit_at_line + 0x8a (fitter_vpr20kmain) 0x439eba: l_compute_and_cache_block_downstream_costs + 0x13da (fitter_vpr20kmain) 0x431606: aa_route_lookahead_setup_cached_lookahead_constants + 0x556 (fitter_vpr20kmain) 0x3ca85f: l_perform_pre_connection_operations + 0x26f (fitter_vpr20kmain) 0x3ca39f: l_route_to_target + 0x21f (fitter_vpr20kmain) 0x3c9c15: l_route_net + 0x4f5 (fitter_vpr20kmain) 0x3c4faf: aa_route_alg_route_all_nets + 0x21f (fitter_vpr20kmain) 0x45da1a: l_rt_prl_worker + 0xca (fitter_vpr20kmain) 0x629771: l_thread_start_wrapper + 0x41 (fitter_vpr20kmain) 0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x18210: mem_thread_wrapper + 0x70 (ccl_mem) 0x2854: thr_thread_begin + 0xa4 (ccl_thr) 0x17613: BaseThreadInitThunk + 0x13 (KERNEL32) 0x526b0: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 22.1std.2 Build: 922 Edition: Standard Edition
What would your suggested way to solve this be? Is there a way for you to understand and solve this issue purely from the above stack traces? Unfortunately i can not share the design, as it is strictly confidential.
Thanks a lot in advance for any suggestions you could provide!
Florian
1 Reply
- ShengN_altera
Sent you an email.
Sheng
