shivajim
2 years agoQuartus Prime 24.1 Tool Crash
Hello, I am using quartus prime pro 24.1 and the tool crashees during the synthesis and analysis phase, please see the attached logs. Can anyone help find/solve this issue? OS: RHEL 7.9 Memory: ...
ShengN_altera
2 years agoHi Shivaji M,
Do they have any other options in the tool that I can dump and share you quickly? your request looks will take some time, and meanwhile I'm trying to narrow down what is causing the crash.
Seems like your ip causes the crash. Engineering team will need your custom ip to identify the fix else it'll be very hard to identify. Probably need to wait for your encrypted ip or after narrowing down.
I'm using an agilex7i AGIB027 device., Can you recommend any other stable Quartus tool version that I can give try, I’m using now 24.1?
If test with older version like 22.1, does the error still exist?
Sheng
