shivajim
2 years agoQuartus Prime 24.1 Tool Crash
Hello, I am using quartus prime pro 24.1 and the tool crashees during the synthesis and analysis phase, please see the attached logs. Can anyone help find/solve this issue? OS: RHEL 7.9 Memory: ...
shivajim
2 years agoHi,
This project contains proprietary IP that cannot be shared. I did a quick check - if I exclude our IP the tool goes through synthesis and generates the netlist, but when I add our IP it crashes, it seems like some loop/some logic is causing the crash, and the same IP synthesizes with xilinx and our tools. Is this due to the license/memory? currently I am compiling with 30 days evaluation license and soon i will be switching to purchased license but not sure the issue is because of this. Also, is there an option in the tool to enable crash debug logs that I can generate during synthesis/elab? which i can share it with you for analysis.
Shivaji M
