ultra205
3 years agoQuartus Prime- Internal Error: Sub-system: PGME, File: /quartus/pgm/pgme/pgme_engine.cpp, Line: 4555
Hello~ Please advise on the following phenomenon~ Environment SW : Quartus Prime SC Lite Edition(22.1 std) FPGA : MAX10(10M08AE144C8G) In the Progammer Add file : *.pof After c...
Nurina
3 years agoHi,
I just noticed you are using MAX 10 on Quartus 22.1std. I'm not sure how you're able to create the project on this version, MAX 10 is not supported in 22.1std/Lite and onwards.
Try using 21.1std/lite as this is the latest Quartus version that supports MAX 10: https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html#intel%C2%AEmax%C2%AEseries
Nurina
ultra205
3 years agoHi~
Problem solved.
Thanks for your advice~
ultra205
